Forcing a Wait Silence |
Special Tag used to discard all pending data from communication until it finds a time-out, indicating that there is no more data to receive.
This service can be configured on the Modbus tab, to occur whenever detecting a communication error. With this Tag, however, users can execute this service at any time by the application.
This Special Tag is executed using a Tag's writing command. Its value, written to the Tag, is ignored.
•Device: Not used, this field must be kept blank
•Item: "ForceWaitSilence"
•N1: Not used, can be left in 0 (zero)
•N2: 9001
•N3: Not used, can be left in 0 (zero)
•N4: Not used, can be left in 0 (zero)
•Value: Not used, can be left in 0 (zero)
