Configuration by Syntactical Parameters
Reading and Writing
Elipse E3 starting with version 2.0, Elipse Power, and Elipse Water allow configuring Tags by syntactic parameters. Use the next syntax for each field:
•The Device field is not used and it must be kept empty
•The Item field must obey the syntax <Area name><Address>[:<Data Type>], in which:
•<Area name> must be filled with a String from table Area Names
•<Address> must be filled with an address in an area or an offset
•<Data type> is optional and, if used, it must be separated by colons and filled with a String from table Data Types. If this data type is omitted, then the default data type for this area is displayed
Area Names
Area
Meaning
Supported Data Types
D
Data register
Word (default), Short, BCD, DWord, Long, LBCD, Float, Double, Date, and String
R
Extension register
TN
Timer value
Word (default), Short, and BCD
TS
Timer contact
Bit (default), Word, Short, BCD, DWord, Long, and LBCD
CN
Counter value
Word (default), Short, BCD, DWord, Long, and LBCD
CS
Counter contact
X
Input
Y
Output
M
Auxiliary relay
S
State
Data Types
Data Type
Meaning
W or WORD
Word value (unsigned 16-bit)
S, SH, or SHORT
Short value (signed 16-bit)
DW or DWORD
Double Word value (unsigned 32-bit)
L or LONG
Long value (signed 32-bit)
F or FLOAT
Floating Point value (32-bit floating point, IEEE 754)
D or DOUBLE
Double Floating Point value (64-bit double precision floating point, IEEE 754)
BCD
BCD value (16-bit)
LBCD
Long BCD value (32-bit)
DATE
32-bit value
STR or STRING
Sequence of String characters
The syntax for the Item field, if the String data type is selected, is the following:
•<Area name><Address>:STR[<Maximum length>], in which:
•<Area name> and <Address> refer to the same items on the general syntax
•<Maximum length> is optional and informs the maximum size declared on the String. If not informed, considers the maximum default size of a String as declared on this Driver's configuration window
NOTE
Any area whose default data type is Bit, when accessed with another data type, must be addressed with a value that is a multiple of 16.
Examples
1.Reading or writing an Input with address 1 (one) and a basic Bit data type: The Item field is filled with "X1".
2.Reading or writing an Output with address 100 and data type configured as Word: The Item field is filled with "Y100:W". Values from 16 contiguous Outputs starting at address 100 are reinterpreted as a Word value.
3.Reading or writing a Counter Value with address 50 and a basic Word data type: The Item field is filled with "CN50". Filling it with "CN50:W" produces the same result.
4.Reading or writing a Data Register with address 1000 and data type configured as Double Word: The Item field is filled with "D1000:DW". Values from two contiguous Data Registers starting at address 1000 are reinterpreted as a Double Word value.
5.Reading or writing a Data Register with address 100 and data type configured as a String with a maximum size of 64: "D100:STR[64]".
