Configuration by Numeric Parameters
Reading and Writing
Addressing fields by N/B parameters
•N1 or B1: Not used, leave it in 0 (zero)
•N2 or B2: Data type and Area. This value must be composed by the sum of data type plus the area (N2 or B2 equal to Data Type Value + Area Value). If the value of Type is equal to 0 (zero), then assumes area's default data type
•N3 or B3: Address value in this area or offset
•N4 or B4: Used only if data type is String. Informs the maximum size declared in a String. If it is not informed, considers the maximum default size of a String as provided on this Driver's configuration window
Area values
Value
Meaning
Supported Data Types
0
Data register
Word (default), Short, BCD, DWord, Long, LBCD, Float, Double, Date, and String
1
Extension register
2
Timer value
Word (default), Short, and BCD
3
Timer contact
Bit (default), Word, Short, BCD, DWord, Long, and LBCD
4
Counter value
Word (default), Short, BCD, DWord, Long, and LBCD
5
Counter contact
6
Input
7
Output
8
Auxiliary relay
9
State
Data type values
Value
Meaning
000
Basic data type of this area (Bit or Word)
100
Bit (value 1 or 0)
200
Word value (unsigned 16-bit)
300
Short value (signed 16-bit)
400
Double Word value (unsigned 32-bit)
500
Long value (signed 32-bit)
600
Floating Point value (32-bit floating point, IEEE 754)
700
Double Floating Point value (64-bit double precision floating point, IEEE 754)
800
BCD value (16-bit)
900
Long BCD value (32-bit)
1000
32-bit value
1100
Sequence of String characters
NOTE
Any area whose default data type is Bit, when accessed with another data type, must be addressed with a value that is a multiple value of 16.
Examples
1.Reading or writing an Input with address 1 (one) and a basic Bit data type: N1 = 0, N2 = 0, N3 = 1, and N4 = 0. If N2 is filled with value "100", then the result is the same.
2.Reading or writing an Output with address 100 and data type configured as Word: N1 = 0, N2 = 202, N3 = 100, and N4 = 0.
3.Reading or writing a Counter Value with address 50 and a basic Word data type: N1 = 0, N2 = 20, N3 = 50, and N4 = 0. If N2 is filled with value "220", then the result is the same.
4.Reading or writing a Data Register with address 1000 and data type configured as Double Word: N1 = 0, N2 = 421, N3 = 1000, and N4 = 0. Values from two contiguous Data Registers starting at address 1000 are reinterpreted as a Double Word.
