[N/B] Parameters for Addressing PLC or Block Tags
N1 or B1
Number of a station
N2 or B2
Number of a CPU from A series (usually 255 for FX series)
N3 or B3
Type of variable. For more information, please check the next table
N4 or B4
Initial address of variables
Size
Number of data points to read (Bit or Word)
NOTES
•By default, Word-type variables are interpreted as unsigned values. To interpret these values as signed (negative values), add the value 1000 to the N3 or B3 parameter. For example, the value 17 indicates a Special Register D variable treated as unsigned and the value 1017 indicates a Special Register D variable treated as signed.
•Some variables are addressed as decimal and some are addressed as hexadecimal. Please do not mismatch these two types when configuring these variables.
Data types of variables
Variable
N3 or B3
Data Type
Input X
0 (zero)
Bit
Output Y
1 (one)
Bit
Internal Relay M
2 (two)
Bit
Latch Relay L
3 (three)
Bit
Step Relay S
4 (four)
Bit
Link Relay B
5 (five)
Bit
Annunciator F
6 (six)
Bit
Special Relay M
7 (seven)
Bit
Timer (contact) T
8 (eight)
Bit
Timer (coil) T
9 (nine)
Bit
Counter (contact) C
10
Bit
Counter (coil) C
11
Bit
Timer (present value) T
12
Word
Counter (present value) C
13
Word
Data Register D
14
Word
Link Register W
15
Word
File Register R
16
Word
Special Register D
17
Word
ANA Input X
18
Bit
ANA Output Y
19
Bit
ANA Internal Relay M
20
Bit
ANA Latch Relay L
21
Bit
ANA Step Relay S
22
Bit
ANA Link Relay B
23
Bit
ANA Annunciator F
24
Bit
ANA Special Relay M
25
Bit
ANA Timer (contact) T
26
Bit
ANA Timer (coil) T
27
Bit
ANA Counter (contact) C
28
Bit
ANA Counter (coil) C
29
Bit
ANA Timer (present value) T
30
Word
ANA Counter (present value) C
31
Word
ANA Data Register D
32
Word
ANA Link Register W
33
Word
ANA File Register R
34
Word
ANA Special Register D
35
Word
