Reading a Digital Input |
N1 |
Address of a Modbus Slave. If this parameter is configured with the value 0 (zero), this Tag uses the address configured in the Default Slave Address option of the ME3011 tab |
N2 |
0 (zero) |
N3 |
Number of a digital input |
N4 |
0 (zero) |
This Tag reads the list of values from the event queue for the digital input defined in the N3 parameter, in the range between 0 (zero) and 255. Please check the documentation for the address of points relative to the position of each device.
