Offline Parameters
Offline Parameters
All parameters described on topic Driver Configuration Window can be changed at run time using Tags from IOKit library. To do so, use the next Strings:
•ION.MasterAddress (Master Address option)
•ION.DefaultSlaveAddress (Default Slave Address option)
•ION.CutDoubleFF (Remove Duplicate FF bytes option)
•ION.NullDRExcept (Data Recorder Exceptions return NULL option)
•ION.UserPwd (Password option)
•ION.UserNumber (User Number option)
•ION.UserSecurityLevel (Use User Security Level option)
