Driver Configuration Window
Driver configuration window
The available options on the ION tab are described on the next table.
Available options on the ION tab
Option
Description
Master Address
Source address, that is, the address assigned to this Driver on the network. It must not match the addresses of meters available on the network (Slave Id)
Default Slave Address
Identifies the address of a meter if the N1 or B1 parameter of a Tag is configured with the value 0 (zero)
Remove Duplicated FF bytes
Removes unwanted FF bytes appearing at the beginning of a frame as a result of a carrier switching if a dedicated communication channel gets noisy
Data Recorder Exceptions return NULL
Returns NULL and not the text or description of an exception informed by a meter during the memory extraction of a data recorder, or mass memory reading
Use User Security Level
Configures this Driver to perform a control on alphanumerical passwords of users
User Number (1 to 16)
User number, between 1 (one) and 16, used by this Driver if the Use User Security Level option is enabled
Password
Alphanumerical password, with up to 6 (six) characters, for the user informed in the User Number (1 to 16) option
For more information about the configuration of Setup, Serial, Ethernet, Modem, and RAS tabs, please check topic Documentation of I/O Interfaces.
