Changing Parameters at Run Time |
All configuration parameters available on the Properties Window can be changed at run time using Tags for writing parameters of the IOKit library, that is, the N1 parameter equal to -1 (minus one), the N2 parameter equal to 0 (zero), the N3 parameter equal to 0 (zero), and the N4 parameter equal to 3 (three). The available parameters are described on the next table.
Available parameters in the IOKit library
Configuration |
Tag |
IEC103_DEFAULT_SLAVE_ADDRESS |
IEC103.DefaultSlaveAddress |
IEC103_APPTIMEOUT |
IEC103.AppTimeout |
IEC103_CONSECFRAMES |
IEC103.ConsecFrames |
IEC103_SYNC |
IEC103.GlobalSync |
IEC103_GENERALINTERROGATION |
IEC103.GeneralInterrogation |
IEC103_POLLTIME |
IEC103.PollTime |
IEC103_GITIME |
IEC103.GITime |
IEC103_SYNCTIME |
IEC103.GlobalSyncTime |
IEC103_COMTRADE_DIR |
IEC103.ComtradeDir |
IEC103_DODISTURBANCE |
IEC103.DoDisturbance |
IEC103_LINKRETRIES |
IEC103.LinkRetries |
IEC103_DEMOTIONTIME |
IEC103.DemotionTime |
IEC103_ANALOG_PRIV_MODE |
IEC103.AnalogPrivateMode |
IEC103_RETURN_DPI |
IEC103.ReturnDPI |
IEC103_RETURN_NULL |
IEC103.ReturnNullOnCommError |
