Configuring Properties
The GenericProtocol tab, shown on the next figure, contains specific settings for this Driver.
GenericProtocol tab
GenericProtocol tab
Available options on the GenericProtocol tab
Option
Description
New Project
Allows creating a new project
Existing Project
Allows selecting an existing project file, in XML format
Project Name
Specifies a name for a project. This field is disabled when selecting the New Project option
Folder Path
Shows the directory where a project is saved
Browse
When selecting the New Project option, this option allows selecting a directory to save this new project. When selecting the Existing Project option, this option allows selecting a project file, in XML format
Name
Specifies a name for a frame
Type
Specifies a type for a frame. Possible values for this option are TX: Transmission frame or RX: Reception frame
Delete All
Deletes all frames from the current project
New Frame
Opens the Frame configuration window, described next, to create a new frame
To change the name of a registered frame in a project, right-click the name of a frame and select the Change Name option to open the window on the next figure.
Change Name window
Change Name window
To remove a registered frame in a project, right-click the name of a frame and select the Delete option. To edit a frame, double-click the name of a frame on the list.
Frame Configuration window
Available options on the Frame Configuration window
Option
Description
Max Size (bytes)
Indicates the maximum valid size, in bytes, for a frame. This value must be in the range between 1 (one) and 1500
Accept Multiple Answers
Enables the configuration of the maximum number of frames received and not read. These frames are stored until the older frames are deleted
Max Accepted Answers
Indica the maximum number of frames received and not read. This value must be in the range between 1 (one) and 256
Field Name
Name of a field
Field Type
Type of a field. Possible values for this option are Data [DT], Delimiter [DL], CheckSum8 [SUM], or CRC
Optional
Indicates whether this field is optional
Requires that another field exists
Indicates whether this field depends on the existence of another field
Add Field
Opens the Data Field Configuration window if the Field Type option was configured with the Data [DT] value, the Delimiter Field Configuration window if the Field Type option was configured with the Delimiter [DL] value, the CheckSum8 Field Configuration window if the Field Type option was configured with the CheckSum8 [SUM] value, or the CRC Field Configuration window if the Field Type option was configured with the CRC value
To change the name of a field registered in a project, right-click the name of a field and select the Change Name option to open the window on the next figure.
Change Name window
Change Name window
To remove a field registered in a frame, right-click the name of a field and select the Delete option. To edit a field, double-click the name of a field on the list. The Message Formats list shows the result of the configured frames, displaying up to 255 valid frames. The Number of Valid Formats option on this window's footer shows the number of valid paths in a frame.
Available options on the Data Field Configuration window
Option
Description
Size Type
Indicates the size of a field. Possible values for this option are Fixed: Fixed size in bytes, Automatic: Variable size without limits, or Bounded: Size in bytes with the possibility of defining a minimum size and a maximum size
Fixed Size
Fixed size of a field, in bytes. This option is only available when selecting the Fixed value in the Size Type option
Minimum Size
Minimum size of a field. This option is only available when selecting the Bounded value in the Size Type option
Maximum Size
Maximum size of a field. This option is only available when selecting the Bounded value in the Size Type option
Type
Indicates how a received data must be interpreted. Possible values for this option are Signed Integer, Unsigned Integer, Decimal, or String
Format
Indicates the format for receiving data. Possible values for this option are ASCII: Text format or HEX: Hexadecimal format (Raw)
'+' Sign in Positive Values
Indicates the presence of a plus (+) sign for positive values when the reception format is equal to ASCII and the data type is a number. Possible values for this option are Optional, Mandatory, or Forbidden
Reverse bits
Applies a bit reversing on received data before processing
Swap WORDS
Applies a swapping of Word values on received data before processing
Swap Bytes
Applies a swapping of bytes on received data before processing
Swap DWORDS
Applies a swapping of DWord values on received data before processing
Validation Type
Indicates whether any additional validation must be performed on the received data. Possible values for this option are No Validation: No validation, Value Limits: Allows setting minimum and maximum limits for a received number, or Value List: Allows defining a list of valid number or String values, based on the data type selected in the Type option
Lower Limit
Minimum value of a field. This option is only available when selecting the Value Limits value in the Validation Type option. By default, the minimum value includes the typed value. To exclude it, select the Exclusive option
Upper Limit
Maximum value of a field. This option is only available when selecting the Value Limits value in the Validation Type option. By default, the maximum value includes the typed value. To exclude it, select the Exclusive option
Valid Value
Allows adding a valid value for the received field. The Valid Values list contains all valid values already registered
To remove a valid value, right-click a value on the Valid Values list and select the Delete option.
Available options on the Delimiter Field Configuration window
Option
Description
Delimiter
Field delimiter
Format
Format of a delimiter. Possible values for this option are ASCII: Delimiter in text format or HEX: Delimiter in hexadecimal format. NOTE: The ASCII option accepts spaces both in the beginning and in the end and the HEX option does not accept spaces and the 0x prefix must be omitted
Available options on the CheckSum8 Field Configuration window
Option
Description
Method
Indicates a calculation method for the checksum. Possible values for this option are XOR: Uses the Exclusive Or method, Modulo: Sums all bytes from the selected region and gets the rest of the division by 256, or Two's Complement: Sums all bytes from the selected region, inverts all bits from the result, and adds 1 (one)
Format
Indicates the format for receiving the data. The possible values for this option are ASCII: Hexadecimal in text format (0xFF represented as "FF") or HEX: Hexadecimal format (Raw)
Swap Nibble
Applies a four-bit permutation to the received data before processing
Start
Selects a frame field where the calculation of the checksum starts
End
Selects a frame field where the calculation of the checksum ends
Available options on the CRC Field Configuration window
Option
Description
Bit Length
Indicates the size of a CRC (Cyclic Redundancy Check) code in bits. Possible values for this option are CRC-8: 8-bit size, CRC-16: 16-bit size, or CRC-32: 32-bit size
Predefined
Indicates a pre-defined type of CRC. Possible values for this option are CRC8, CRC8_8H2F, CRC8_CDMA200, CRC8_DARC, CRC8_DVB_S2, CRC8_EBU, CRC8_ICODE, CRC8_ITU, CRC8_MAXIM, CRC8_ROHC, CRC8_SAE_J1850, CRC8_SAE_J1850_ZERO, or CRC8_WCDMA
Custom
Allows customizing a type of CRC. Selecting this option enables the next options
Input Reflected
Reverts the received bytes
Result Reflected
Reverts the calculated CRC code
Polynomial
Polynomial value of the CRC code, in hexadecimal format without spaces and omitting the 0x prefix
Initial Value
Initial value of the Exclusive Or method of the CRC code, in hexadecimal format without spaces and omitting the 0x prefix
Final Xor Value
Final value of the Exclusive Or method of the CRC code, in hexadecimal format without spaces and omitting the 0x prefix
Format
Indicates the format for receiving a CRC. Possible values for this option are ASCII: Hexadecimal in text format (0xFF represented as "FF") or HEX: Hexadecimal format (Raw)
Reverse bits
Applies a bit reversing on the received CRC before processing
Swap WORDS
Applies a swapping of Word values on the received CRC before processing
Swap Bytes
Applies a swapping of bytes on the received CRC before processing
Start
Select the frame field where the calculation of the CRC code starts
End
Select the frame field where the calculation of the CRC code ends
NOTE
All windows automatically save their changes, except the main window to configure this Driver. In this case, click Apply to save in-memory changes and click OK to save all changes and close the window.
