IO.TAPI.Dial
IO.TAPI.Dial
Type of Tag
I/O Tag
Type of Access
Write-Only
N1 Parameter
-1 (minus one)
N2 Parameter
0 (zero)
N3 Parameter
3 (three)
N4 Parameter
1 (one)
String Configuration
IO.TAPI.Dial
Write any value to this Tag to force a Modem Interface to start a call. This is an asynchronous command, only starting the call process. Users can monitor the IO.TAPI.IsModemConnected Tag to detect when a call is established.
