IO.TAPI.IsModemConnected
Type of Tag
I/O Tag
Type of Access
Read-Only
N1 Parameter
-1 (minus one)
N2 Parameter
0 (zero)
N3 Parameter
3 (three)
N4 Parameter
3 (three)
String Configuration
This Tag indicates the status of a modem connection. Possible values are 0: The modem is not connected, but it may be performing or receiving an external call or 1: The modem is connected and the Driver completed or received an external call successfully. While it is in this status, the physical layer can send or receive data.
