IO.Serial.CTSTimeoutMs
Integer Time to wait for a CTS signal, in milliseconds. After turning the RTS signal on, a timer is started to wait for a CTS signal. If this timer expires, the Driver aborts sending bytes through the serial port. Available only when the IO.Serial.RTS property is configured as Toggle and the IO.Serial.WaitCTS property is configured to True.
