IO.Serial.RTS
IO.Serial.RTS
String Indicates how a Driver deals with the RTS signal. Possible values are OFF: RTS signal always off, ON: RTS signal always on, or Toggle: Turns the RTS signal on when transmitting data and turns the RTS signal off when not transmitting data.
