SequenceOfUnsigned32
This XML representation of complex data is used by the following objects/properties:
•channel.controlGroups
XML Schema
  <xs:complexType name="SequenceOfUnsigned32">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="Unsigned32" type="Unsigned32" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfUnsigned32" />
</xs:schema>
Examples
Example 1:
  <SequenceOfUnsigned32 />
</Value>
Example 2:
  <SequenceOfUnsigned32>
    <Unsigned32>2345</Unsigned32>
    <Unsigned32>2346</Unsigned32>
    <Unsigned32>2347</Unsigned32>
  </SequenceOfUnsigned32>
</Value>
