SequenceOfREAL
SequenceOfREAL
This XML representation of complex data is used by the following objects/properties:
•networkPort.linkSpeeds
XML Schema
  <xs:complexType name="SequenceOfREAL">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="REAL" type="REAL" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfREAL" />
</xs:schema>
Examples
Example 1:
  <SequenceOfREAL />
</Value>
Example 2:
  <SequenceOfREAL>
    <REAL>1234.567749</REAL>
    <REAL>1235.567749</REAL>
    <REAL>1236.567749</REAL>
  </SequenceOfREAL>
</Value>
