SequenceOfReadAccessSpecification
This XML representation of complex data is used by the following objects/properties:
•group.listOfGroupMembers
XML Schema
  <xs:complexType name="SequenceOfReadAccessSpecification">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="ReadAccessSpecification" type="ReadAccessSpecification" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfReadAccessSpecification" />
</xs:schema>
Examples
Example 1:
  <SequenceOfReadAccessSpecification />
</Value>
Example 2:
  <SequenceOfReadAccessSpecification>
    <ReadAccessSpecification>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <ListOfPropertyReferences />
    </ReadAccessSpecification>
      <ObjectIdentifier>device-502</ObjectIdentifier>
      <ListOfPropertyReferences>
        <BACnetPropertyReference>
          <PropertyIdentifier>action</PropertyIdentifier>
          <PropertyArrayIndex>1237</PropertyArrayIndex>
        </BACnetPropertyReference>
      </ListOfPropertyReferences>
      <ObjectIdentifier>device-505</ObjectIdentifier>
          <PropertyIdentifier>activeVtSessions</PropertyIdentifier>
          <PropertyArrayIndex>1240</PropertyArrayIndex>
  </SequenceOfReadAccessSpecification>
</Value>
Example 3:
      <ObjectIdentifier>device-508</ObjectIdentifier>
          <PropertyIdentifier>all</PropertyIdentifier>
          <PropertyArrayIndex>1243</PropertyArrayIndex>
          <PropertyIdentifier>apduSegmentTimeout</PropertyIdentifier>
          <PropertyArrayIndex>1245</PropertyArrayIndex>
          <PropertyIdentifier>applicationSoftwareVersion</PropertyIdentifier>
          <PropertyArrayIndex>1247</PropertyArrayIndex>
      <ObjectIdentifier>device-515</ObjectIdentifier>
          <PropertyIdentifier>changeOfStateCount</PropertyIdentifier>
          <PropertyArrayIndex>1250</PropertyArrayIndex>
      <ObjectIdentifier>device-518</ObjectIdentifier>
          <PropertyIdentifier>controlledVariableReference</PropertyIdentifier>
          <PropertyArrayIndex>1253</PropertyArrayIndex>
</Value>
