SequenceOfOctetString
This XML representation of complex data is used by the following objects/properties:
•networkPort.ipDnsServer
•networkPort.ipv6DnsServer
XML Schema
  <xs:complexType name="SequenceOfOctetString">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="OctetString" type="OctetString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfOctetString" />
</xs:schema>
Examples
Example 1:
  <SequenceOfOctetString />
</Value>
Example 2:
  <SequenceOfOctetString>
    <OctetString>00010203040506070809</OctetString>
    <OctetString>FF</OctetString>
  </SequenceOfOctetString>
</Value>
