SequenceOfBACnetVTClass
This XML representation of complex data is used by the following objects/properties:
•device.vtClassesSupported
XML Schema
  <xs:complexType name="SequenceOfBACnetVTClass">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetVTClass" type="BACnetVTClass" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetVTClass" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetVTClass />
</Value>
Example 2:
  <SequenceOfBACnetVTClass>
    <BACnetVTClass>defaultTerminal</BACnetVTClass>
    <BACnetVTClass>ansiX364</BACnetVTClass>
    <BACnetVTClass>decVt52</BACnetVTClass>
  </SequenceOfBACnetVTClass>
</Value>
