SequenceOfBACnetVMACEntry
This XML representation of complex data is used by the following objects/properties:
•networkPort.virtualMacAddressTable
XML Schema
  <xs:complexType name="SequenceOfBACnetVMACEntry">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetVMACEntry" type="BACnetVMACEntry" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetVMACEntry" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetVMACEntry />
</Value>
Example 2:
  <SequenceOfBACnetVMACEntry>
    <BACnetVMACEntry>
      <VirtualMacAddress>00010203040506070809</VirtualMacAddress>
      <NativeMacAddress>00010203040506070809</NativeMacAddress>
    </BACnetVMACEntry>
    <BACnetVMACEntry>
      <VirtualMacAddress>FF</VirtualMacAddress>
      <NativeMacAddress>FF</NativeMacAddress>
    </BACnetVMACEntry>
    <BACnetVMACEntry>
    </BACnetVMACEntry>
  </SequenceOfBACnetVMACEntry>
</Value>
