SequenceOfBACnetRouterEntry
This XML representation of complex data is used by the following objects/properties:
•networkPort.routingTable
XML Schema
  <xs:complexType name="SequenceOfBACnetRouterEntry">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetRouterEntry" type="BACnetRouterEntry" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetRouterEntry" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetRouterEntry />
</Value>
Example 2:
  <SequenceOfBACnetRouterEntry>
    <BACnetRouterEntry>
      <NetworkNumber>7634</NetworkNumber>
      <MacAddress>00010203040506070809</MacAddress>
      <Status>busy</Status>
      <PerformanceIndex>35</PerformanceIndex>
    </BACnetRouterEntry>
    <BACnetRouterEntry>
      <NetworkNumber>7637</NetworkNumber>
      <MacAddress>FF</MacAddress>
      <PerformanceIndex>38</PerformanceIndex>
    <BACnetRouterEntry>
      <NetworkNumber>7640</NetworkNumber>
      <PerformanceIndex>41</PerformanceIndex>
  </SequenceOfBACnetRouterEntry>
</Value>
