SequenceOfBACnetRecipient
This XML representation of complex data is used by the following objects/properties:
•device.restartNotificationRecipients
•device.timeSynchronizationRecipients
•device.utcTimeSynchronizationRecipients
•globalGroup.covuRecipients
XML Schema
  <xs:complexType name="SequenceOfBACnetRecipient">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetRecipient" type="BACnetRecipient" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetRecipient" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetRecipient />
</Value>
Example 2:
  <SequenceOfBACnetRecipient>
    <BACnetRecipient>
      <Device>device-501</Device>
    </BACnetRecipient>
    <BACnetRecipient>
      <Device>device-502</Device>
    </BACnetRecipient>
    <BACnetRecipient>
      <Device>device-503</Device>
    </BACnetRecipient>
  </SequenceOfBACnetRecipient>
</Value>
