SequenceOfBACnetOptionalCharacterString
This XML representation of complex data is used by the following objects/properties:
•characterstringValue.alarmValues
•characterstringValue.faultValues
XML Schema
  <xs:complexType name="SequenceOfBACnetOptionalCharacterString">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetOptionalCharacterString" type="BACnetOptionalCharacterString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetOptionalCharacterString" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetOptionalCharacterString />
</Value>
Example 2:
  <SequenceOfBACnetOptionalCharacterString>
    <BACnetOptionalCharacterString>
      <Null />
    </BACnetOptionalCharacterString>
      <Null />
      <Null />
  </SequenceOfBACnetOptionalCharacterString>
</Value>
