SequenceOfBACnetLogMultipleRecord
This XML representation of complex data is used by the following objects/properties:
•trendLogMultiple.logBuffer
XML Schema
  <xs:complexType name="SequenceOfBACnetLogMultipleRecord">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLogMultipleRecord" type="BACnetLogMultipleRecord" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLogMultipleRecord" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetLogMultipleRecord />
</Value>
Example 2:
  <SequenceOfBACnetLogMultipleRecord>
    <BACnetLogMultipleRecord>
      <Timestamp>
        <Date>2017-12-20</Date>
        <Time>22:39:15.980</Time>
      </Timestamp>
      <LogData>
        <LogStatus>
          <logDisabled>true</logDisabled>
          <logInterrupted>true</logInterrupted>
        </LogStatus>
      </LogData>
    </BACnetLogMultipleRecord>
      <Timestamp>
        <Date>2018-12-20</Date>
      </Timestamp>
      <LogData>
        <LogStatus>
        </LogStatus>
      </LogData>
      <Timestamp>
        <Date>2019-12-20</Date>
      </Timestamp>
      <LogData>
        <LogStatus>
        </LogStatus>
      </LogData>
  </SequenceOfBACnetLogMultipleRecord>
</Value>
