SequenceOfBACnetEventNotificationSubscription
This XML representation of complex data is used by the following objects/properties:
•notificationForwarder.subscribedRecipients
XML Schema
  <xs:complexType name="SequenceOfBACnetEventNotificationSubscription">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetEventNotificationSubscription" type="BACnetEventNotificationSubscription" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetEventNotificationSubscription" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetEventNotificationSubscription />
</Value>
Example 2:
  <SequenceOfBACnetEventNotificationSubscription>
    <BACnetEventNotificationSubscription>
      <Recipient>
        <Device>device-501</Device>
      </Recipient>
      <ProcessIdentifier>2346</ProcessIdentifier>
      <IssueConfirmedNotifications>true</IssueConfirmedNotifications>
      <TimeRemaining>1236</TimeRemaining>
    </BACnetEventNotificationSubscription>
      <Recipient>
        <Device>device-504</Device>
      </Recipient>
      <ProcessIdentifier>2349</ProcessIdentifier>
      <TimeRemaining>1239</TimeRemaining>
      <Recipient>
        <Device>device-507</Device>
      </Recipient>
      <ProcessIdentifier>2352</ProcessIdentifier>
      <TimeRemaining>1242</TimeRemaining>
  </SequenceOfBACnetEventNotificationSubscription>
</Value>
