SequenceOfBACnetEscalatorFault
This XML representation of complex data is used by the following objects/properties:
•escalator.faultSignals
XML Schema
  <xs:complexType name="SequenceOfBACnetEscalatorFault">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetEscalatorFault" type="BACnetEscalatorFault" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetEscalatorFault" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetEscalatorFault />
</Value>
Example 2:
  <SequenceOfBACnetEscalatorFault>
    <BACnetEscalatorFault>controllerFault</BACnetEscalatorFault>
    <BACnetEscalatorFault>driveAndMotorFault</BACnetEscalatorFault>
    <BACnetEscalatorFault>mechanicalComponentFault</BACnetEscalatorFault>
  </SequenceOfBACnetEscalatorFault>
</Value>
