SequenceOfBACnetDoorAlarmState
This XML representation of complex data is used by the following objects/properties:
•accessDoor.alarmValues
•accessDoor.faultValues
•accessDoor.maskedAlarmValues
XML Schema
  <xs:complexType name="SequenceOfBACnetDoorAlarmState">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetDoorAlarmState" type="BACnetDoorAlarmState" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetDoorAlarmState" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetDoorAlarmState />
</Value>
Example 2:
  <SequenceOfBACnetDoorAlarmState>
    <BACnetDoorAlarmState>normal</BACnetDoorAlarmState>
    <BACnetDoorAlarmState>alarm</BACnetDoorAlarmState>
    <BACnetDoorAlarmState>doorOpenTooLong</BACnetDoorAlarmState>
  </SequenceOfBACnetDoorAlarmState>
</Value>
