SequenceOfBACnetDestination
This XML representation of complex data is used by the following objects/properties:
•notificationClass.recipientList
•notificationForwarder.recipientList
XML Schema
  <xs:complexType name="SequenceOfBACnetDestination">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetDestination" type="BACnetDestination" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetDestination" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetDestination />
</Value>
Example 2:
  <SequenceOfBACnetDestination>
    <BACnetDestination>
      <ValidDays>
        <monday>true</monday>
        <wednesday>true</wednesday>
        <friday>true</friday>
        <sunday>true</sunday>
      </ValidDays>
      <FromTime>22:39:15.980</FromTime>
      <ToTime>22:39:15.980</ToTime>
      <Recipient>
        <Device>device-503</Device>
      </Recipient>
      <ProcessIdentifier>2348</ProcessIdentifier>
      <IssueConfirmedNotifications>true</IssueConfirmedNotifications>
      <Transitions>
        <toOffnormal>true</toOffnormal>
        <toNormal>true</toNormal>
      </Transitions>
    </BACnetDestination>
    <BACnetDestination>
      <ValidDays>
      </ValidDays>
      <Recipient>
        <Device>device-507</Device>
      </Recipient>
      <ProcessIdentifier>2352</ProcessIdentifier>
      <Transitions>
      </Transitions>
    <BACnetDestination>
      <ValidDays>
      </ValidDays>
      <Recipient>
        <Device>device-511</Device>
      </Recipient>
      <ProcessIdentifier>2356</ProcessIdentifier>
      <Transitions>
      </Transitions>
  </SequenceOfBACnetDestination>
</Value>
