SequenceOfBACnetCalendarEntry
This XML representation of complex data is used by the following objects/properties:
•calendar.dateList
XML Schema
  <xs:complexType name="SequenceOfBACnetCalendarEntry">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetCalendarEntry" type="BACnetCalendarEntry" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetCalendarEntry" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetCalendarEntry />
</Value>
Example 2:
  <SequenceOfBACnetCalendarEntry>
    <BACnetCalendarEntry>
      <Date>2017-12-20</Date>
    </BACnetCalendarEntry>
      <Date>2018-12-20</Date>
      <Date>2019-12-20</Date>
  </SequenceOfBACnetCalendarEntry>
</Value>
