SequenceOfBACnetAccessCredentialDisableReason
This XML representation of complex data is used by the following objects/properties:
•accessCredential.reasonForDisable
XML Schema
  <xs:complexType name="SequenceOfBACnetAccessCredentialDisableReason">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAccessCredentialDisableReason" type="BACnetAccessCredentialDisableReason" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAccessCredentialDisableReason" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAccessCredentialDisableReason />
</Value>
Example 2:
  <SequenceOfBACnetAccessCredentialDisableReason>
    <BACnetAccessCredentialDisableReason>disabled</BACnetAccessCredentialDisableReason>
    <BACnetAccessCredentialDisableReason>disabledNeedsProvisioning</BACnetAccessCredentialDisableReason>
    <BACnetAccessCredentialDisableReason>disabledUnassigned</BACnetAccessCredentialDisableReason>
  </SequenceOfBACnetAccessCredentialDisableReason>
</Value>
