BACnetDailySchedule
BACnetDailySchedule
This XML representation of complex data is used by the following objects/properties:
•schedule.weeklySchedule
XML Schema
  <xs:complexType name="BACnetDailySchedule">
    <xs:sequence>
      <xs:element name="DaySchedule" type="SequenceOfBACnetTimeValue" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetDailySchedule" />
</xs:schema>
Examples
Example 1:
  <BACnetDailySchedule>
    <DaySchedule />
  </BACnetDailySchedule>
</Value>
Example 2:
    <DaySchedule>
      <BACnetTimeValue>
        <Time>22:39:15.980</Time>
        <Value>
          <Boolean>true</Boolean>
        </Value>
      </BACnetTimeValue>
      <BACnetTimeValue>
        <Value>
        </Value>
      </BACnetTimeValue>
      <BACnetTimeValue>
        <Value>
        </Value>
      </BACnetTimeValue>
    </DaySchedule>
</Value>
