BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences |
<xs:complexType name="BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences">
<xs:sequence>
<xs:element minOccurs="0" maxOccurs="unbounded" name="ListOfCovReferences_Item" type="BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences_Item" />
</xs:sequence>
</xs:complexType>
Example 1:
<SequenceOfBACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences />
Example 2:
<SequenceOfBACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences>
<ListOfCovReferences />
<ListOfCovReferences>
<ListOfCovReferences_Item>
<MonitoredProperty>
<PropertyIdentifier>ackedTransitions</PropertyIdentifier>
<PropertyArrayIndex>1235</PropertyArrayIndex>
</MonitoredProperty>
<CovIncrement>1236.567749</CovIncrement>
<Timestamped>true</Timestamped>
</ListOfCovReferences_Item>
</ListOfCovReferences>
<MonitoredProperty>
<PropertyIdentifier>actionText</PropertyIdentifier>
<PropertyArrayIndex>1238</PropertyArrayIndex>
<CovIncrement>1239.567749</CovIncrement>
</SequenceOfBACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences>
Example 3:
<MonitoredProperty>
<PropertyIdentifier>alarmValue</PropertyIdentifier>
<PropertyArrayIndex>1241</PropertyArrayIndex>
<CovIncrement>1242.567749</CovIncrement>
<MonitoredProperty>
<PropertyIdentifier>allWritesSuccessful</PropertyIdentifier>
<PropertyArrayIndex>1244</PropertyArrayIndex>
<CovIncrement>1245.567749</CovIncrement>
<MonitoredProperty>
<PropertyIdentifier>applicationSoftwareVersion</PropertyIdentifier>
<PropertyArrayIndex>1247</PropertyArrayIndex>
<CovIncrement>1248.567749</CovIncrement>
<MonitoredProperty>
<PropertyIdentifier>changeOfStateCount</PropertyIdentifier>
<PropertyArrayIndex>1250</PropertyArrayIndex>
<CovIncrement>1251.567749</CovIncrement>
<MonitoredProperty>
<PropertyIdentifier>controlledVariableReference</PropertyIdentifier>
<PropertyArrayIndex>1253</PropertyArrayIndex>
<CovIncrement>1254.567749</CovIncrement>
