BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences_Item |
<xs:complexType name="BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences_Item">
<xs:sequence>
<xs:element name="MonitoredProperty" type="BACnetPropertyReference" />
<xs:element minOccurs="0" name="CovIncrement" type="REAL" />
<xs:element name="Timestamped" type="Boolean" />
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences_Item>
<MonitoredProperty>
<PropertyIdentifier>ackedTransitions</PropertyIdentifier>
<PropertyArrayIndex>1235</PropertyArrayIndex>
</MonitoredProperty>
<CovIncrement>1236.567749</CovIncrement>
<Timestamped>true</Timestamped>
</BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item_ListOfCovReferences_Item>
Example 2:
<MonitoredProperty>
<PropertyIdentifier>actionText</PropertyIdentifier>
<PropertyArrayIndex>1238</PropertyArrayIndex>
