multiStateOutput.eventState |
Indicates if this object has an active event state associated with it.
Property eventState of object multiStateOutput can be read and written using a single IOTag.
multiStateOutput-<objectAddress>.eventState |
<type> = 14 |
<property> = 36 |
An integer representing one of the options of enumeration <BACnetEventState>.
