BACnetEventState
BACnetEventState
This enumeration is used by the following objects/properties:
•accessDoor.eventState
•accessPoint.eventState
•accessZone.eventState
•accumulator.eventState
•alertEnrollment.eventState
•analogInput.eventState
•analogOutput.eventState
•analogValue.eventState
•binaryInput.eventState
•binaryOutput.eventState
•binaryValue.eventState
•bitstringValue.eventState
•channel.eventState
•characterstringValue.eventState
•command.eventState
•credentialDataInput.eventState
•dateValue.eventState
•datepatternValue.eventState
•datetimeValue.eventState
•datetimepatternValue.eventState
•device.eventState
•escalator.eventState
•eventEnrollment.eventState
•eventLog.eventState
•globalGroup.eventState
•integerValue.eventState
•largeAnalogValue.eventState
•lifeSafetyPoint.eventState
•lifeSafetyZone.eventState
•lift.eventState
•loadControl.eventState
•loop.eventState
•multiStateInput.eventState
•multiStateOutput.eventState
•multiStateValue.eventState
•networkPort.eventState
•notificationClass.eventState
•octetstringValue.eventState
•positiveIntegerValue.eventState
•program.eventState
•pulseConverter.eventState
•schedule.eventState
•timeValue.eventState
•timepatternValue.eventState
•timer.eventState
•trendLog.eventState
•trendLogMultiple.eventState
The enumeration values are:
Value
Name
0
normal
1
fault
2
offnormal
3
highLimit
4
lowLimit
5
lifeSafetyAlarm
