Add or Edit a BACnet Device |
When clicking Add or Edit on the BACnet tab the window on the next figure is opened.
Add/Edit BACnet device window
This window contains the properties described on the next table.
Available properties on the Add/Edit BACnet device window
Description |
Device Instance |
Device's identifier |
Segmentation Support |
Type of packet segmentation supported by a device |
Segments Accepted |
Acceptable number of segments for exchanging segmented messages. Select accordingly to what is determined in a device's configuration |
Maximum APDU Length Accepted |
Maximum length number in octets per message segment. This means that if the request or response exceeds this maximum value, the message must be segmented into as many segments as necessary. Select accordingly to what is determined in a device's configuration |
Maximum number of objects per ReadMultipleRequest |
If the Disable Read Grouping option is deselected, this Driver performs grouped requests of several Tags that cannot be read spontaneously (COV). This option indicates the maximum number of items requested at the same time in these readings |
Inter-Message Delay (milliseconds) |
Delay, in milliseconds, between sent messages |
Get Alarm Summary at startup |
Performs a request to retrieve a list of alarms during this Driver's initialization. That retrieved list is then sent to the special Tag ReceiveEventNotifications |
Device IP |
IP address of a device |
Enable Network Address |
Select this option to allow editing a device's sub-network and MAC addresses |
Network Address |
Mask used on the IP address, which corresponds to the DNET field in a BACnet packet |
MAC Address |
MAC address of a device, which corresponds to the DADR field in a BACnet packet |
Enable Write Priority |
Select this option to allow specifying a writing priority to a device |
Write Priority |
Select this option to specify a priority used on all writing commands to properties sent to this device, between 1 (one) and 16. If this option is not selected, this Driver uses the default priority (16) |
Use COV |
Enables the system of spontaneous messages (Change of Value, or COV), sent by a device when the value changes. They are typically used for properties of type presentValue and StatusFlags. Please check topic COV System for more information |
Use Confirmed COV |
If enabled, informs that COV messages sent by a device must be confirmed. Otherwise, these messages do not need confirmation |
Maximum COV Subscriptions |
Informs a maximum number of variables that can be monitored by a device for spontaneous sending. After that limit, additional Tags are read by polling |
Exclude Analog objects from COV |
When this option is enabled, readings of analog values in this device are not performed by COV notifications |
COV Subscription Lifetime (seconds) |
Time, in seconds, in which a COV subscription for this device is valid. A value of 0 (zero) indicates that a subscription never expires. This Driver renews expired subscriptions automatically |
SubscribeCOV Delay (milliseconds) |
Delay, in milliseconds, between sending a request for a COV subscription and the next message |
