DrugEntry
DrugEntry
Read and Write
This Block Tag must contain 27 Elements. All names and fill rules for each one of these Elements are described on the next table. Depending on the operation performed, reading or writing, this Tag follows the set of behaviors described next.
Write
Writing must be performed as an entire block operation, that is, writing only Block Elements is not allowed. This operation stores in an internal memory a candidate for a new Drug item, which is processed according to the command selected in the operations of the DrugEntryOperation Tag.
Read
Displays all Drug items stored in this Driver's internal memory list. This reading returns a list of N blocks of Drug items, where N is the number of items in memory.
Format of a DrugEntry Block Tag
Element
Parameter
Format
Rule
Element 1
DrugId
String
Optional
Element 2
DrugName
String
Please check Rule 1 (one)
Element 3
DrugShort
String with a maximum of 8 (eight) characters
Element 4
CatalogName
String
Optional
Element 5
TherapyMode
ListTherapyModeOptions
Optional
Element 6
InfusionRate
Number with a decimal point
Optional
Element 7
RateUnit
ListRateUnitOptions
Please check Rule 2 (two)
Element 8
VtbiValue
Please check Rule 3 (three)
Element 9
VtbiUnit
ListVtbiUnitOptions
Element 10
AmountValue
Optional
Element 11
AmountUnit
ListAmountUnitOptions
Element 12
VolumeValue
Positive integer
Please check Rule 4 (four)
Element 13
VolumeUnit
ListVolumeUnitOptions
Element 14
TotalDose
Optional
Element 15
TotalDoseUnit
ListTotalDoseUnitOptions
Element 16
TotalTime
Positive integer
Optional
Element 17
TotalTimeUnit
ListTotalTimeUnitOptions
Element 18
PatientID
String
Optional
Element 19
NurseID
String
Optional
Element 20
HeightValue
Optional
Element 21
HeightUnit
ListHeightUnitOptions
Element 22
WeightValue
Optional
Element 23
WeightUnit
ListWeightUnitOptions
Element 24
BodySurfaceAreaValue
Optional
Element 25
BodySurfaceAreaUnit
ListBodySurfaceAreaUnitOptions
Element 26
OrderNumber
String with a maximum of 19 number characters
Optional
Element 27
PumpId
String
Please check Rule 5 (five)
Format Types
All Elements must be filled as Strings obeying the format described on the previous table.
•Number format with a decimal point: It may have decimal places after a point. For example, 10.0 or 10 are valid values
•Positive integer format: Without decimal places. For example, 10, 20, or 1000 are valid values
Fill Rules
There is no need to fill all Elements, because several of them are optional, but users must follow these rules:
•Rule 1: DrugName or DrugShort Elements must be filled. Only one of these Elements must be filled and the other one must be omitted
•Rule 2: It is mandatory to fill this Element if the previous Element is filled, otherwise it must be omitted
•Rule 3: It is optional, but if the TotalTime Element is filled, it must be omitted
•Rule 4: It is mandatory to fill if the AmountValue and AmountUnit Elements are filled, otherwise it must be omitted
•Rule 5: It is optional, but when filling it, users must obey the ISP or PSP prefixes, followed by decimal number digits
Writing this Block Tag by Script
The next script is an example on how to fill an Array and write it to this Block Tag.
Dim Arr(26) 'Array DrugList
Arr(1)  = "ampicillin"   'DrugName
Arr(3)  = "2749283"      'CatalogName
Arr(4)  = "Intermittent" 'TherapyMode
Arr(5)  = "200.0"        'InfusionRate
Arr(6)  = "ml/h"         'RateUnit
Arr(7)  = "100.0"        'VtbiValue
Arr(8)  = "ml"           'VtbiUnit
Arr(9)  = "1000.0"       'AmountValue
Arr(10) = "mg"           'AmountUnit
Arr(11) = "100.0"        'VolumeValue
Arr(12) = "ml"           'VolumeUnit
Arr(13) = "1000.0"       'TotalDose
Arr(14) = "mg"           'TotalDoseUnit
Arr(25) = "3488817"      'OrderNumber
Arr(26) = "ISP154133"    'PumpId
Set Driver = Application.GetObject("DriverAutoProgramming")
'Write DrugList
Driver.Item("DrugEntry").WriteEx Arr
