[P] Parameters for Driver Configuration
P1
Not used
P2
Not used
P3
Not used
P4
Not used
This Driver does not use [P] configuration parameters. All settings of this Driver must be performed on the configuration window.
The APR03 tab on the configuration window displays specific settings for this Driver. The other tabs allow configuring communication parameters of the IOKit library. For more information about the configuration of the IOKit library, please check topic Documentation of I/O Interfaces.
