Configuration File for Reading Data by Event
To edit a configuration file for reading data by event, click Table Config File on the APR03 tab. In this file, users can define the addresses of variables and pointers to control the reading of data tables, as well as the format of each table. The fields that must be defined in this file are described on the next table.
Fields of a configuration file
Field
Description
RECORD POINTER ADDRESS
Value of the recording pointer's address, in decimal
TABLE STATUS ADDRESS
Value of the table's status address, in decimal
ACQUISITION STATUS ADDRESS
Value of the acquisition's status address, in decimal
TABLE
Number of a table format to define, between 0 (zero) and 65535. There is no need to use a colon between the keyword and the number
REGISTERS
Maximum number of records or structures a table must support in its buffer. This value define the size of a circular buffer reserved for a table
START ADDRESS
Initial address of a table, in decimal, in which the circular buffer reserved for a table starts
PACKET SIZE
Maximum size of a data block that can be transferred at each communication with a device, in bytes. This value depends on the device used. The larger, the less communication is needed to read all data
STRUCT
Defines a structure for each record of a table. Its members must be defined by integer values equivalent to data types interpreted by this Driver
Users can add comment lines to a file by using the // characters, according to the pattern used by the C language. The topic Reading Data by Event analyzes this feature in details.
