Performing a Data Collecting
The AnsiC12xx Driver was designed to turn an application created with an Elipse Software's product into a telemetering application. Therefore, most likely the main usage is to perform data collecting tasks.
The main data collecting operations that can be performed on meters implementing Ansi C12.19 data tables are Load Profile, History Log, and Event Log.
