Configuração Dinâmica
Este Driver permite que alguns parâmetros de configuração sejam informados em tempo de execução por script, usando o comando de escrita de parâmetros da biblioteca IOKit. Estes parâmetros estão descritos na tabela a seguir.
Parâmetros de configuração
Propriedade
Parâmetro
Tipo de Dados
Total Device Number
IEC61850.DeviceCount
DWORD
Server
IEC61850.Device[%u].Name
STRING
IP
IEC61850.Device[%u].IP
STRING
Backup IP
IEC61850.Device[%u].IPBackup
STRING
PSEL
IEC61850.Device[%u].PSel
DWORD
SSEL
IEC61850.Device[%u].SSel
DWORD
TSEL
IEC61850.Device[%u].TSel
DWORD
Rem AE Qual
IEC61850.Device[%u].AEQualifier
DWORD
Rem AP ID
IEC61850.Device[%u].AppID
STRING
Disable
IEC61850.Device[%u].Disable
BYTE
Use Backup IP
IEC61850.Device[%u].UseIPBackup
BYTE
Save Comtrade (Per Device)
IEC61850.Device[%u].SaveComtrade
BYTE
Delete Comtrade Files (Per Device)
IEC61850.Device[%u].DeleteComtrade
BYTE
Browse Root Folder Only (Per Device)
IEC61850.Device[%u].BrowseRootFolderOnly
BYTE
Comtrade Path (Per Device)
IEC61850.Device[%u].ComtradePath
STRING
Use Fixed Comtrade Path On Device (Per Device)
IEC61850.Device[%u].UseFixedPathOnDevice
BYTE
Name+Index File Transfer
IEC61850.Device[%u].NameAndIndexFileTransfer
BYTE
File Root Name
IEC61850.Device[%u].FileTransferRootName
STRING
Prefer Buffered Report Control Blocks
IEC61850.UseReports
BYTE
User-Defined Report List
IEC61850.UserReportList
BYTE
Poll Tags not found in any report
IEC61850.PollTags
BYTE
Local P Selector
IEC61850.LocalPSel
DWORD
Local S Selector
IEC61850.LocalSSel
DWORD
Local T Selector
IEC61850.LocalTSel
DWORD
Local AE Qualifier
IEC61850.LocalAEQualifier
DWORD
Local App ID
IEC61850.LocalAppID
STRING
RFC 1006 Source TSAP
IEC61850.SourceTSAP
DWORD
App Category
IEC61850.AppCategory
STRING
Polled Intg Rpt
IEC61850.RptGI
DWORD
Auto Intg Prt
IEC61850.IntgPd
DWORD
Use Quality change trigger
IEC61850.UseQChgTrgOps
BYTE
Conformance Blocks (internal use)
IEC61850.CBB
STRING
Services (internal use)
IEC61850.Services
STRING
LD File Path
IEC61850.LDPath
STRING
Comtrade Path
IEC61850.ComtradePath
STRING
Comtrade Directory on Device (internal use)
IEC61850.ComtradeDir
STRING
Msg Timeout
IEC61850.Timeout
DWORD
Full Log Details
IEC61850.DetailedLog
BYTE
Save Comtrade Files
IEC61850.SaveComtrade
BYTE
Save Comtrade Per IED
IEC61850.SaveComtradePerIED
BYTE
Delete Files after upload
IEC61850.DeleteComtrade
BYTE
Comtrade Directory Check Interval
IEC61850.CheckComtrade
BYTE
Comtrade Upload Interval
IEC61850.UploadComtrade
DWORD
Check Report Time of Entry
IEC61850.RedundantBRCB
BYTE
Status Check
IEC61850.StatusCheck
DWORD
Asynchronous Write
IEC61850.AsyncWrite
BYTE
Use Single Tag Command Alias
IEC61850.SingleTagCmdAlias
BYTE
Apply Local Time Offset to Timestamps
IEC61850.ApplyLocalTime
BYTE
Use Cmd Tag N1 as check condition
IEC61850.SingleTagCmdN1
BYTE
No LD Database Scan
IEC61850.NoLDScan
BYTE
IEC61850.ComtradeBrowseRootFolderOnly
BYTE
Use Exclusive URCB
IEC61850.ReserveURCB
BYTE
Um exemplo de configuração COMTRADE dinâmica está descrito a seguir:
1.Este Driver deve ter todos os IEDs já declarados, e devem estar com a opção Disable configurada com o valor 1 (um). Isto evita que a comunicação inicie com os parâmetros incorretos.
2.Este Driver deve também estar com a opção Define Parameters Per IED configurada.
3.No evento AfterStart deve haver um script que altera os parâmetros de cada IED. Estes parâmetros devem ser escritos via biblioteca IOKit. Os parâmetros estão indicados no script a seguir, em que %u deve ser trocado pelo índice do IED neste Driver, começando com 0 (zero). Estes parâmetros estão disponíveis no log deste Driver.
"IEC61850.Device[%u].SaveComtrade"
"IEC61850.Device[%u].DeleteComtrade"
"IEC61850.Device[%u].BrowseRootFolderOnly"
"IEC61850.Device[%u].ComtradePath"
"IEC61850.Device[%u].UseFixedPathOnDevice"
"IEC61850.Device[%u].NameAndIndexFileTransfer"
"IEC61850.Device[%u].FileTransferRootName"
4.Considere que os parâmetros ComtradePath e FileTransferRootName são do tipo String e que, se o valor individual por IED não está configurado, considera-se o valor padrão definido na janela de propriedades. O valor padrão para as demais propriedades é 0 (zero, Falso).
5.Após escrever os parâmetros desejados, habilite cada IED escrevendo o valor 0 (zero) no parâmetro "IEC61850.Device[%u].Disable".
6.Inicie a comunicação com este Driver escrevendo o valor 1 (um) no Tag especial ServerInitialBuild. Este Tag cria os Hosts que estão habilitados e que ainda não foram criados.
' Exemplo considerando um array de 8 (oito) Elementos
' Os índices vazios são ignorados por este Driver
Dim Arr(8)
Arr(1) = Array("IEC61850.Device[0].SaveComtrade",1) ' Este IED busca Comtrades
Arr(2) = Array("IEC61850.Device[1].SaveComtrade",0) ' Este IED não busca Comtrades
Arr(3) = Array("IEC61850.Device[2].SaveComtrade",1) ' Este IED busca Comtrades
Arr(4) = Array("IEC61850.Device[2].NameAndIndexFileTransfer",1) ' Este IED busca Comtrades usando RootName + Index
Arr(5) = Array("IEC61850.Device[0].Disable",0) ' Habilita IED
Arr(6) = Array("IEC61850.Device[1].Disable",0) ' Habilita IED
Arr(7) = Array("IEC61850.Device[2].Disable",0) ' Habilita IED
Driver.Write -1,0,0,3 Arr ' Escreve parâmetros
Driver.Item("ServerInitialBuild").WriteEx 1 'Supondo a existencia deste Tag com o parâmetro Item = ServerInitialBuild,
'ao escrever 1 (um) inicia a comunicação com todos os IEDs habilitados
7.Ao parar este Driver, estes parâmetros não são salvos, por isso o evento AfterStart deve continuar existindo para que, ao iniciar este Driver, os IEDs sejam configurados corretamente.
