trendLogMultiple.totalRecordCount |
Represents the total number of log records collected by the Trend Log object since creation. When the value of Total_Record_Count reaches its maximum possible value of 232 - 1, the next value it takes shall be one. Once this value has wrapped to one, its semantic value (the total number of log records collected) has been lost but its use in generating notifications remains.
A propriedade totalRecordCount do objeto trendLogMultiple pode ser lida e escrita utilizando um tag normal (IOTag).
trendLogMultiple-<endereçoDoObjeto>.totalRecordCount |
<tipo> = 27 |
<propriedade> = 145 |
