trendLogMultiple.recordsSinceNotification |
Represents the number of log records collected since the previous notification, or since the beginning of logging if no previous notification has occurred.
A propriedade recordsSinceNotification do objeto trendLogMultiple pode ser lida e escrita utilizando um tag normal (IOTag).
trendLogMultiple-<endereçoDoObjeto>.recordsSinceNotification |
<tipo> = 27 |
<propriedade> = 140 |
