trendLog.eventAlgorithmInhibit |
Indicates whether (TRUE) or not (FALSE) the event algorithm has been disabled for the object. This property is a runtime override that allows temporary disabling of the event algorithm. If the Event_Algorithm_Inhibit_Ref property is present and initialized (contains an instance other than 4194303), then the Event_Algorithm_Inhibit property shall be read-only and shall reflect the value of the property referenced by Event_Algorithm_Inhibit_Ref. A BACnetBinaryPV value of INACTIVE shall map to a value of FALSE and a value of ACTIVE shall map to a value of TRUE. If the referenced property does not exist, it shall be assumed to have a value of FALSE.
A propriedade eventAlgorithmInhibit do objeto trendLog pode ser lida e escrita utilizando um tag normal (IOTag).
trendLog-<endereçoDoObjeto>.eventAlgorithmInhibit |
<tipo> = 20 |
<propriedade> = 354 |
