timer.initialTimeout |
Indicates the initial timeout, in milliseconds, that was taken as initial duration to count down when the timer last transitioned to state RUNNING.
A propriedade initialTimeout do objeto timer pode ser lida e escrita utilizando um tag normal (IOTag).
timer-<endereçoDoObjeto>.initialTimeout |
<tipo> = 31 |
<propriedade> = 394 |
