structuredView.subordinateTags |
Provides individual collections of tags for each of the subordinates. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Annotations, Subordinate_Node_Types, and Subordinate_Relationships arrays, if present, shall also be changed to the same size. Uninitialized Subordinate_Tags array elements shall be empty collections.
A propriedade subordinateTags do objeto structuredView pode ser lida e escrita utilizando um tag normal (IOTag).
structuredView-<endereçoDoObjeto>.subordinateTags |
<tipo> = 29 |
<propriedade> = 488 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetNameValueCollection>.
