structuredView.subordinateRelationships |
Describes the relationship to each member of the Subordinate_List. If this property is absent, then relationship to each of the subordinates is equal to the value of the Default_Subordinate_Relationship property, if present, else equal to UNKNOWN. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Annotations, Subordinate_Tags, and Subordinate_Node_Types arrays, if present, shall also be changed to the same size. Uninitialized Subordinate_Relationships array elements shall be equal to DEFAULT.
A propriedade subordinateRelationships do objeto structuredView pode ser lida e escrita utilizando um tag normal (IOTag).
structuredView-<endereçoDoObjeto>.subordinateRelationships |
<tipo> = 29 |
<propriedade> = 489 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetRelationship>.
