structuredView.subordinateAnnotations |
Used to define a text string description for each member of the Subordinate_List. The content of these strings is not restricted. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Tags, Subordinate_Relationships, and Subordinate_Node_Types arrays shall also be changed to the same size.
A propriedade subordinateAnnotations do objeto structuredView pode ser lida e escrita utilizando um tag normal (IOTag).
structuredView-<endereçoDoObjeto>.subordinateAnnotations |
<tipo> = 29 |
<propriedade> = 210 |
Um string contendo um XML com um valor do tipo <SequenceOfCharacterString>.
