structuredView.nodeType |
Provides a general classification of the object in the hierarchy of objects. It is intended as a general suggestion to a client application about the contents of a Structured View object, and is not intended to convey an exact definition. Further refinement of classification is provided by the Node_Subtype property.
A propriedade nodeType do objeto structuredView pode ser lida e escrita utilizando um tag normal (IOTag).
structuredView-<endereçoDoObjeto>.nodeType |
<tipo> = 29 |
<propriedade> = 208 |
Um inteiro representando uma das opções da enumeração <BACnetNodeType>.
