structuredView.nodeSubtype |
Contains a string of printable characters whose content is not restricted. It provides a more specific classification of the object in the hierarchy of objects, providing a short description of the item represented by the node.
A propriedade nodeSubtype do objeto structuredView pode ser lida e escrita utilizando um tag normal (IOTag).
structuredView-<endereçoDoObjeto>.nodeSubtype |
<tipo> = 29 |
<propriedade> = 207 |
