structuredView.defaultSubordinateRelationship |
Describes the default relationship to each member of the Subordinate_List, unless overridden by a member of the Subordinate_Relationships property. If this property is absent and the Subordinate_Relationships is also absent, the relationship to the subordinates is equal to UNKNOWN.
A propriedade defaultSubordinateRelationship do objeto structuredView pode ser lida e escrita utilizando um tag normal (IOTag).
structuredView-<endereçoDoObjeto>.defaultSubordinateRelationship |
<tipo> = 29 |
<propriedade> = 490 |
Um inteiro representando uma das opções da enumeração <BACnetRelationship>.
